TTE1XX 1.0TSI UPGRADE TURBOCHARGER.
Riddick
Bericht door Riddick » zo 01 mar 2020, 10:53
The Turbo Engineers.
Product information "TTE1XX 1.0TSI UPGRADE TURBOCHARGER"
TTE1XX is our very latest hybrid performance upgrade turbocharger based on the Original BorgWarner turbocharger for the VAG 1.0TSI 115PS found in the UP GTI and others in the VAG range. The TTE1XX offers good spool, response, and power. We feel this is the best performing upgrade turbocharger on offer today.
Engineered & Enhanced
To construct a TTE1XX we change the original compressor and employ a far larger and more efficient 6+6 billet wheel with extended tip technology and mill the compressor cover to the optimum gap to match the new compressor profile. We replace the original turbine and CNC mill the turbine housing to install a larger 10 blade turbine for greater gas flow. We also replace the original thrust bearing for TTE upgrade 360 deg that is made in-house.
The 10 Blade TTE turbine is a special turbine. Advantages are greater gas flow, reducing back pressure and lowering exhaust gas temperatures, allowing safer higher boost levels.
Equilibrium
Precisely balancing our turbochargers is a key critical factor to become a TTE upgrade unit as longevity and performance are paramount. Good balance improves acoustics also. Subsequent great care is taken with all TTE turbochargers to achieving our balance standards. Firstly parts are balanced at slow speeds up to 2800RPM in multiple planes using our single parts machine, then components are assembled and then the CHRA are dynamically balanced, but this time depending on application at up to 250,000 RPM in multiple planes using our in house VSR machine to acquire the ultimate equilibrium, to a standard far higher than OEM. Each turbocharger is supplied with a serial numbered balance test result document.
Product Highlights:
Original Genuine BorgWarner turbocharger as the base part
Original Genuine actuator
Original Genuine diverter valve
TTE Billet Milled 6+ 6 compressor
TTE High-Flow 10 Blade Turbine
TTE Reinforced bearing pack
Plug & Play installation
150+hp Capable
Proven TheTurboEngineers quality
Single parts finely balanced then components assembled and core high-speed VSR balanced
Supplied with a balance test result document
Made in Germany
https://tteglobal.co.uk/vw/up/gti-1.0-t ... rbocharger
Re: TTE1XX 1.0TSI UPGRADE TURBOCHARGER.
Bericht door Down » zo 01 mar 2020, 17:38
Oww gaaf zo iets lijkt me nog wel een keer wat.
Wie weet van de zomer :twisted:
kgroot.nl
Bericht door kgroot.nl » ma 02 mar 2020, 08:30
150PK+ oftewel een dure oplossing voor een paar PK.
Laat het een keer 160PK zijn maar dan zal de fut er wel uit zijn
Bericht door Tom Westendorp » ma 02 mar 2020, 11:52
Ik vraag me af hoeveel boost te veel zal worden voor de 1.0 TSI. Je kunt er wel 180 pk uithalen maar als de motor dan nog maar 20k kilometer meegaat, wat heb je er dan precies aan?
Bericht door damianw26 » ma 02 mar 2020, 15:51
Ben sowieso erg benieuwd wanneer een gechipte TSI toe is aan een revisie. Als je het vermogen niet gebruikt vervuilt hij ontzettend van binnen na verloop van tijd, en als je altijd topsnelheid rijdt en plankgas optrekt heb je versnelde slijtage. Gelukkig heeft iedere up een 15.000km 1 jaar interval om olie te wisselen, dat scheelt al een hoop. Al valt of staat alles met de gebruiker uiteraard.
Bericht door Down » ma 02 mar 2020, 16:33
Ja dat is natuurlijk wel een punt de duurzaamheid.
Hoop er toch wel 200000km op te rijden.
Als ik het zo lees is een grotere turbo dan niet de beste keus.
Arjan-tsi
Bericht door Arjan-tsi » za 21 mar 2020, 11:45
https://www.facebook.com/25928359424509 ... 991673807/ 220pk en 300 nm ik weet niet wat er nog meer is aangepast
Bericht door Down » za 21 mar 2020, 12:59
Wauw gaaf zeg zijn mooie cijfers.
JEROEN206
Bericht door JEROEN206 » vr 03 jul 2020, 12:39
up te koop in duitsland met TTE turbo.
Staat ook op YouTube bij SAR techniek
https://www.ebay-kleinanzeigen.de/s-anz ... 8-216-6688
Vw High UP! TSI Bluemotion , Drive pakket , DAB+, 135Pk-230NM Vagtechniek ,18"OZ Ultraleggera,KW schroefset.
Bericht door damianw26 » vr 03 jul 2020, 13:50
Gaaf, alleen 190pk zonder versterkte internals. Gaat vast niet heel lang goed als je het vermogen regelmatig gebruikt.
Bericht door Caddykaatje » vr 03 jul 2020, 14:40
Denk dat binnen de kortste keren de drijfstangen rond je oren vliegen 🤣
Bericht door NidayFright » vr 03 jul 2020, 22:46
Kan je net zo goed je portemonnee op straat gooien :doh:
